KC868-H32B V4.23 new firmware update
improvement:
1. Support MQTT by ethernet.
2. Fixed bug that can't use 2pcs KC868-H32B by WiFI MQTT at the same time. Now no limit, multi controller can be used at the same time.
3. Relay "Momentary Time" extend to "1-10000 seconds"
4. add scan device Broadcast command for UDP. This command for software developer scan KC868-H32B in network.
use local network port=4000  send Ansi-String "scan" to remote IP:255.255.255.255 Port:4001
all KC868-H32B in same network device will feedback: device's IP,Port,UID,type
for example:
send->scan
feedback: 192.168.1.200:4196,uid:xxxxxxxxxxxxxxxxxxxxxxxx,type:H32B
KC868-H32B V4.23 firmware download:
download the ZIP file , unzip update the bin file for KC868-H32B relay controller by USB-RS232 cable.
.zip   Relay32_V423_210505.zip (Size: 44.96 KB / Downloads: 1,153)
How do I reset my password settings? After setting the password, I can't log in through the management web page. LAN connection.
Hold on "ethernet" button, when the [yellow and white and blue LED] all is ON, release it, then work mode in “TCP Server” and IP (192.168.1.200) by static mode;then password will reset to user name:admin  password:admin
The First Moment After Updating my H32W everything was fine.
 i introduced the MQTT Settings and after a restart the device is no more reachable and it also don´t connect to the MQTT Broker. The Configuration Web-Portal (in my case 192.168.1.56) is not Reachable to check the settings. Is it Possible the Reset the Device to Factory Settings? Thank You.
It seems to be Connected via Ethernet to My Router:
The Device Refuse Connection:
this firmware is for H32B, not for H32W, give me your email, I send you original firmware, you need to download again. Now only H32B support MQTT function.
