CT Clamp
Hi, I would like to as for help connecting a SCT013 10A CT clamp to one of the analog inputs.
Thank you for help
CT clamp should connect to KC868-M16 or M16v2 board.
KC868-A8 not have level convert circuit.
(08-23-2023, 12:12 PM)admin Wrote: CT clamp should connect to KC868-M16 or M16v2 board.
Would it be possible to use external level covert circuit? And use vcc from temp sensor connector?i
the CT sensor is output dc 0-1v signal, it's a little small, you can try to connect to ADC 0-5v channel, but i think the value will not be too precise.
