06-02-2021, 09:53 PM
I also get wrong username and password error, when I try to update firmware on 4.29. Bootloader and everything went ok, I get the web page of the controller (admin/admin does not work), also all the switch terminal board inputs work.
Also I noticed when I try to switch the relays with my previeos configuration in Node-Red, that the controller is very slow, and responds to commands with a delay or does not respond at all.
With 4.20 fw all worked ok. Every week or so I had to reset the controller, because it did not respond on my commands - switch terminal board commands and HA(node red) commands.
