help in configuring and connecting the measurement probes connected to the KC868-COLB
(08-06-2021, 10:46 AM)IOTHDF Wrote: Thank you for your answers.
That said, I do not understand your sentence : Measure the 12V voltage output from the control box (voltage between the blue and white lines).
I confirm that the power supply output on the KC868-Colb PLC does supply a voltage of 12 volts to the wind sensor whose blue wire (negative pole) and white wire (positive pole) are connected.
However, if the wind sensor is configured correctly, why is the Kincony SBC app not showing any numeric input value?
I specify that this wind sensor should normally provide three types of measurements which are the measurement of the wind speed, measurement of the level of rain and the measurement of the luminosity.
Apart from only one, the brown wire is connected to the digital input D1 + of the PLC.
How does the PLC read the 3 measurements (wind, rain and light) with a single wire connected to the KC868-Colb PLC ?
On the 4 wires coming out of the wind sensor, the black wire is not connected. Should it be connected to the PLC? If so at what location?
I would like to point out that this sensor was purchased on your Kincony online web store and that it was delivered to us naked without any user manual, with a diagram explaining how to connect it to the PLC and how to adjust it.
Thank you for enlightening us on these points.
Looking forward to your response, best regards, IOTHDF Member.
you can watch this video.
https://www.youtube.com/watch?v=jxoWdEbd...K&index=12
Wind, light, rain any sensor triggered the brown line will send a DI signal
you can connect the brown line to DI2+ Or other DI+
This is the parameter adjustment knob, you can set it.
RE: help in configuring and connecting the measurement probes connected to the KC868-COLB - by KinCony Support - 08-09-2021, 12:43 AM
