A4 supported power voltage range
Do you mean the "relay coil" will get hot?
[Image: a4-relays.jpg]
The datasheet for the JQC-3FF 12V relays says the voltage limit at 20°C is 14.4V. That is a normal range of 12V nominal systems.
The other components in the Power Supply section have tolerances of 35-40V, so can you help us understand the 12V limit instead of 14.4V from the datasheet?
[Image: a4-power.jpg]
Is there another component on the board causing the relay to overheat?
A4 supported power voltage range - by mikesloper - 02-03-2024, 12:32 PM
RE: A4 supported power voltage range - by admin - 02-03-2024, 01:16 PM
RE: A4 supported power voltage range - by cabinlab - 02-05-2024, 02:56 AM
RE: A4 supported power voltage range - by admin - 02-05-2024, 05:01 AM
