AC voltage and calibration
#30
[quote pid="11787" dateline="1708112777"]
Quote:I hope I get the power factor rather stable for the loads I want to measure, but we'll see.
Was also my plan: will use an accurate socket power meter and read the power factor and then use this as a static value to calculate the power.  Could work for always-on devices or devices with stable power factor.
But there are also quite a few devices for which the power factor varies greatly, especially when they are in standby or some low/medium/high mode (like my ventilation unit - or my oven in standby vs in use because of the electronics/digital clock). My led drivers are also a pain to measure.
Maybe I can take multiple measurements depending on the state and then apply some if-then-else logic for the calculation in esphome or home assistant.
I should give up on trying to be watt-accurate, after all I would be happy to be able to get a good overview of the distribution of my energy usage throughout the house.
Quote:That's what I was afraid to see. Good to know I need to find smaller resistive loads as well. My current lowest is around 0.65A but some loads I want to measure get down to 0.1A.
I think that should work. 0.1.
Btw, a tip to get more calibration points: you can just wrap the wire around the CT multiple times. e.g. if you have a stable 1A load and you wrap it around 4 times you can use that as a reference point for a 4A load.
Quote:Wouldn't it be better to measure on actual wires in the walls? I believe the readings may be influenced by plenty of wires around in my fuse box.
I just calibrated them outside my cabinet before installing them on the lines I needed. But during testing I tried to move and wiggle them around but that didn't seem to affect the readings.
Didn't see a difference between having 1 or all 16 lined up next to each other, so I think that is quite ok.
[/quote]
AC voltage and calibration - by nickdd - 12-04-2023, 06:25 PM
RE: AC voltage and calibration - by nickdd - 12-04-2023, 10:03 PM
RE: AC voltage and calibration - by admin - 12-06-2023, 06:24 AM
RE: AC voltage and calibration - by admin - 12-09-2023, 01:26 PM
RE: AC voltage and calibration - by nickdd - 12-17-2023, 10:52 PM
RE: AC voltage and calibration - by admin - 12-18-2023, 12:36 AM
RE: AC voltage and calibration - by nickdd - 12-18-2023, 02:17 PM
RE: AC voltage and calibration - by admin - 12-18-2023, 11:05 PM
RE: AC voltage and calibration - by nickdd - 12-18-2023, 11:11 PM
RE: AC voltage and calibration - by admin - 12-18-2023, 11:33 PM
RE: AC voltage and calibration - by nickdd - 12-19-2023, 09:54 AM
RE: AC voltage and calibration - by admin - 12-19-2023, 11:12 AM
RE: AC voltage and calibration - by nickdd - 12-19-2023, 03:19 PM
RE: AC voltage and calibration - by admin - 12-20-2023, 12:15 AM
RE: AC voltage and calibration - by nickdd - 12-21-2023, 09:05 PM
RE: AC voltage and calibration - by admin - 12-31-2023, 02:03 PM
RE: AC voltage and calibration - by nickdd - 01-02-2024, 04:59 PM
RE: AC voltage and calibration - by admin - 01-03-2024, 12:42 AM
RE: AC voltage and calibration - by nickdd - 01-07-2024, 10:29 AM
RE: AC voltage and calibration - by admin - 01-07-2024, 11:10 AM
RE: AC voltage and calibration - by nickdd - 01-21-2024, 11:36 PM
RE: AC voltage and calibration - by admin - 01-22-2024, 12:32 AM
RE: AC voltage and calibration - by hamilton - 02-04-2024, 06:27 PM
RE: AC voltage and calibration - by sanurss - 02-15-2024, 04:20 PM
RE: AC voltage and calibration - by nickdd - 02-15-2024, 04:58 PM
RE: AC voltage and calibration - by sanurss - 02-16-2024, 11:55 AM
RE: AC voltage and calibration - by admin - 02-16-2024, 12:11 PM
RE: AC voltage and calibration - by nickdd - 02-16-2024, 07:25 PM
RE: AC voltage and calibration - by sanurss - 02-16-2024, 07:46 PM
RE: AC voltage and calibration - by nickdd - 02-16-2024, 10:51 PM
RE: AC voltage and calibration - by sanurss - 02-17-2024, 08:11 PM
RE: AC voltage and calibration - by nickdd - 02-17-2024, 09:51 PM
RE: AC voltage and calibration - by sanurss - 02-18-2024, 07:25 AM
RE: AC voltage and calibration - by sanurss - 03-22-2024, 03:42 PM
RE: AC voltage and calibration - by admin - 03-22-2024, 11:29 PM
