04-11-2024, 06:53 PM
I have edited the configuration yaml of home assistant. After saving the updated file and re booting the server, the configured outputs of KC868-H32B did not appear on the Home Assistant. The output of the smart panel server appeared but refused to activate.
I restored the original Configuration yaml of the HA. re booted but the output of the smart panel are still not activating the relays.
All the individual servers work locally as shown in the screenshots.
the configuration files are as follows:
Updated
default_config:
frontend:
script: !include scripts.yaml
scene: !include scenes.yaml
modbus:
- name: hub1
type: serial
baudrate: 9600
bytesize: 8
method: rtu
parity: N
port: /dev/ttyS0
stopbits: 1
sensors:
- name: meter-voltage
slave: 1
address: 100
input_type: holding
data_type: float32
precision: 2
unit_of_measurement: V
device_class: voltage
- name: meter-current
slave: 1
address: 106
input_type: holding
data_type: float32
precision: 2
unit_of_measurement: A
device_class: current
- name: meter-power
slave: 1
address: 118
input_type: holding
data_type: float32
precision: 2
unit_of_measurement: kW
device_class: power
- name: meter-factor
slave: 1
address: 142
input_type: holding
data_type: float32
precision: 2
# unit_of_measurement:
device_class: power_factor
- name: meter-frequency
slave: 1
address: 144
input_type: holding
data_type: float32
precision: 2
unit_of_measurement: Hz
device_class: frequency
- name: meter-consumption
slave: 1
address: 0
input_type: holding
data_type: float32
precision: 2
unit_of_measurement: kWh
device_class: energy_storage
mqtt:
- name: 'output-1'
unique_id: output-1
state_topic: 'server/7ffd88f939adfbe3816e4404/state'
command_topic: 'server/7ffd88f939adfbe3816e4404/set'
payload_on: '{"relay1":{"on":1}}'
payload_off: '{"relay1":{"on":0}}'
state_on: 1
state_off: 0
- name: 'output-2'
unique_id: output-2
payload_on: '{"relay2":{"on":1}}'
payload_off: '{"relay2":{"on":0}}'
value_template: '{{ value_json.relay2.on }}'
state_on: 1
state_off: 0
- name: 'output-3'
unique_id: output-3
payload_on: '{"relay3":{"on":1}}'
payload_off: '{"relay3":{"on":0}}'
value_template: '{{ value_json.relay3.on }}'
state_on: 1
state_off: 0
- name: 'output-4'
unique_id: output-4
payload_on: '{"relay4":{"on":1}}'
payload_off: '{"relay4":{"on":0}}'
value_template: '{{ value_json.relay4.on }}'
state_on: 1
state_off: 0
- name: 'output-5'
unique_id: output-5
payload_on: '{"relay5":{"on":1}}'
payload_off: '{"relay5":{"on":0}}'
value_template: '{{ value_json.relay5.on }}'
state_on: 1
state_off: 0
- name: 'output-6'
unique_id: output-6
payload_on: '{"relay6":{"on":1}}'
payload_off: '{"relay6":{"on":0}}'
value_template: '{{ value_json.relay6.on }}'
state_on: 1
state_off: 0
- name: 'output-7'
unique_id: output-7
payload_on: '{"relay7":{"on":1}}'
payload_off: '{"relay7":{"on":0}}'
value_template: '{{ value_json.relay7.on }}'
state_on: 1
state_off: 0
- name: 'output-8'
unique_id: output-8
payload_on: '{"relay8":{"on":1}}'
payload_off: '{"relay8":{"on":0}}'
value_template: '{{ value_json.relay8.on }}'
state_on: 1
state_off: 0
- name: 'output-9'
unique_id: output-9
payload_on: '{"relay9":{"on":1}}'
payload_off: '{"relay9":{"on":0}}'
value_template: '{{ value_json.relay9.on }}'
state_on: 1
state_off: 0
- name: 'output-10'
unique_id: output-10
payload_on: '{"relay10":{"on":1}}'
payload_off: '{"relay10":{"on":0}}'
value_template: '{{ value_json.relay10.on }}'
state_on: 1
state_off: 0
- name: 'output-11'
unique_id: output-11
payload_on: '{"relay11":{"on":1}}'
payload_off: '{"relay11":{"on":0}}'
value_template: '{{ value_json.relay11.on }}'
state_on: 1
state_off: 0
- name: 'output-12'
unique_id: output-12
payload_on: '{"relay12":{"on":1}}'
payload_off: '{"relay12":{"on":0}}'
value_template: '{{ value_json.relay12.on }}'
state_on: 1
state_off: 0
- name: 'output-13'
unique_id: output-13
payload_on: '{"relay13":{"on":1}}'
payload_off: '{"relay13":{"on":0}}'
value_template: '{{ value_json.relay13.on }}'
state_on: 1
state_off: 0
- name: 'output-14'
unique_id: output-14
payload_on: '{"relay14":{"on":1}}'
payload_off: '{"relay14":{"on":0}}'
value_template: '{{ value_json.relay14.on }}'
state_on: 1
state_off: 0
- name: 'output-15'
unique_id: output-15
payload_on: '{"relay15":{"on":1}}'
payload_off: '{"relay15":{"on":0}}'
value_template: '{{ value_json.relay15.on }}'
state_on: 1
state_off: 0
- name: 'output-16'
unique_id: output-16
payload_on: '{"relay16":{"on":1}}'
payload_off: '{"relay16":{"on":0}}'
value_template: '{{ value_json.relay16.on }}'
state_on: 1
state_off: 0
#removed the binary sensor
mqtt:
broker: 192.168.1.200
port: 1883
username: mqtt
password: 123
- name: 'output-17'
unique_id: output-17
state_topic: 'relay32/8ae082ec66f37db231cf2b8f/state'
command_topic: 'relay32/8ae082ec66f37db231cf2b8f/set'
payload_on: '{“relay1”:{“on”:1}}'
payload_off: '{“relay1”:{“on”:0}}'
state_on: 1
state_off: 0
- name: 'output-18'
unique_id: output-18
payload_on: '{“relay2”:{“on”:1}}'
payload_off: '{“relay2”:{“on”:0}}'
state_on: 1
state_off: 0
Updated
default_config:
frontend:
modbus:
- name: hub1
type: serial
baudrate: 9600
bytesize: 8
method: rtu
parity: N
port: /dev/ttyS0
stopbits: 1
sensors:
slave: 1
address: 100
input_type: holding
data_type: float32
precision: 2
slave: 1
address: 106
input_type: holding
data_type: float32
precision: 2
- name: meter-power
slave: 1
address: 118
input_type: holding
data_type: float32
precision: 2
device_class: power
slave: 1
address: 142
input_type: holding
data_type: float32
precision: 2
slave: 1
address: 144
input_type: holding
data_type: float32
precision: 2
slave: 1
address: 0
input_type: holding
data_type: float32
precision: 2
mqtt:
- name: 'output-1'
unique_id: output-1
state_on: 1
state_off: 0
- name: 'output-2'
unique_id: output-2
state_on: 1
state_off: 0
- name: 'output-3'
unique_id: output-3
state_on: 1
state_off: 0
- name: 'output-4'
unique_id: output-4
state_on: 1
state_off: 0
- name: 'output-5'
unique_id: output-5
state_on: 1
state_off: 0
- name: 'output-6'
unique_id: output-6
state_on: 1
state_off: 0
- name: 'output-7'
unique_id: output-7
state_on: 1
state_off: 0
- name: 'output-8'
unique_id: output-8
state_on: 1
state_off: 0
- name: 'output-9'
unique_id: output-9
state_on: 1
state_off: 0
- name: 'output-10'
state_on: 1
state_off: 0
- name: 'output-11'
state_on: 1
state_off: 0
- name: 'output-12'
state_on: 1
state_off: 0
- name: 'output-13'
state_on: 1
state_off: 0
- name: 'output-14'
state_on: 1
state_off: 0
- name: 'output-15'
state_on: 1
state_off: 0
- name: 'output-16'
state_on: 1
state_off: 0
mqtt:
port: 1883
username: mqtt
password: 123
- name: 'output-17'
state_on: 1
state_off: 0
- name: 'output-18'
state_on: 1
state_off: 0
