ENQUIRE ON PROSPECTED SMART HOME PROJECT
QUESTIONS:
- Can i integrate smart touch wall switches as a second level control and alternative switch for designated gadget like ceiling led lighting point for manual control?
>> you can use "momentary" wall switches for second level control way. Not use "SMART" type switch. Because of our controller support "momentary" switch.
- In case of KC868 server goes down or hanged. Can kincony manual switch work effectively.
>> sure, it's no problem, this is important.
- Can i assign IP address to the kincony server from my home router network without using the sim card, so that it can access internet from my home internet router.
>> KinCony Server mainly use for local network, so if without SIM card, it also work with ethernet. you can use DHCP or STATIC ip address.
- Can i integrate my water pump level switch to the controller to control the pumping for water to the reservoir.
>> sure, just your "switch" output dry contact signal, so that you can connect to KinCony controller's digital input ports.
- Can i integrate a physical timer switch to control designated output for designated gadget or do you have a software that can take care of the timing of some output/terminal from the server.
>> you can use "physical timer", or you can use software timer . Both supportted.
if you will use home assistant software. you can use one KinCony Server16 for local server. then you can add any KinCony ESP32 controller, such as KC868-AIO, add some DC contactor for your loads.
RE: ENQUIRE ON PROSPECTED SMART HOME PROJECT - by admin - 06-17-2024, 10:39 PM
