Problem with Yaml demo file
(07-18-2024, 11:59 AM)admin Wrote: if you want download firmware for A16 board.  Do you have remove the RF433M receiver module? it MUST removed from PCB socket.
i removed the rf device.
still getting this message from the esp home assist:  INFO ESPHome 2024.7.0
INFO Reading configuration /config/esphome/esphome-web-fe42e8.yaml...
ERROR Error while reading config: Invalid YAML syntax:
Duplicate key "– id"
  in "/config/esphome/esphome-web-fe42e8.yaml", line 32, column 1
NOTE: Previous declaration here:
  in "/config/esphome/esphome-web-fe42e8.yaml", line 29, column 1
the code is good until here:
– id: ‘pcf8574_hub_out_1’ # for output channel 1-8              this is line 29
address: 0x24
– id: ‘pcf8574_hub_out_2’ # for output channel 9-16
address: 0x25
– id: ‘pcf8574_hub_in_1’ # for input channel 1-8                this is line 32
address: 0x21
– id: ‘pcf8574_hub_in_2’ # for input channel 9-16
address: 0x22
# Individual outputs
– platform: gpio
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
INFO ESPHome 2024.7.0 INFO ESPHome 2024.7.0
Problem with Yaml demo file - by Bigh - 07-18-2024, 11:08 AM
RE: Problem with Yaml demo file - by admin - 07-18-2024, 11:59 AM
RE: Problem with Yaml demo file - by Bigh - 07-18-2024, 07:38 PM
RE: Problem with Yaml demo file - by admin - 07-18-2024, 08:55 PM
RE: Problem with Yaml demo file - by Bigh - 07-19-2024, 07:06 AM
RE: Problem with Yaml demo file - by admin - 07-19-2024, 12:57 PM
RE: Problem with Yaml demo file - by Bigh - 07-19-2024, 01:30 PM
RE: Problem with Yaml demo file - by admin - 07-19-2024, 10:17 PM
