KC868-E16S - Multiple
1. you can download KCS firmware to E16S board , then integrate to home assistant by MQTT , here is yaml samle code for A8S, but E16S is similar, you only replace model with A16 and your own UID: https://www.kincony.com/forum/showthread.php?tid=3274
2. if you want each momentary switch to toggle outputs, just set in IFTTT by KCS firmware, that is stable and better. because this IFTTT work locally by ESP32, if you set by MQTT , manager by home assistant. If home assistant is broken, then all your switch can't work.
KC868-E16S - Multiple - by keithc - 05-17-2023, 02:13 PM
RE: KC868-E16S - Multiple - by admin - 05-17-2023, 02:19 PM
RE: KC868-E16S - Multiple - by keithc - 07-31-2024, 05:35 PM
RE: KC868-E16S - Multiple - by admin - 08-01-2024, 12:46 AM
RE: KC868-E16S - Multiple - by keithc - 08-01-2024, 06:24 PM
RE: KC868-E16S - Multiple - by admin - 08-01-2024, 11:18 PM
RE: KC868-E16S - Multiple - by keithc - 08-02-2024, 09:12 AM
RE: KC868-E16S - Multiple - by admin - 08-02-2024, 12:27 PM
