KC868-Server Raspberry Pi4 local server
#15
(08-29-2024, 08:46 AM)admin Wrote: let KC868-Server and KC868-H32B Pro controller integrate to home assistant by MQTT.
here is guide use by KC868-H32B Pro: https://www.kincony.com/kc868-h32b-integ...-mqtt.html
if you want integrate KC868-Server 16 channel OUTPUT , just modify the MQTT topic name. here is config yaml file: https://www.kincony.com/forum/showthread.php?tid=1780
I have managed to write the yaml for hc868 server and h32b_pro. kc868 server 16 channel can trigger the relays/contactors from the home assistant. H32B_Pro cannot trigger the relays from home assistant.  All configs seems fine, as per the screenshots. What could be responsible?
RE: KC868-Server Raspberry Pi4 local server - by fdcemb5 - 08-29-2024, 08:28 PM
