ATF Arduino source code - Save DS18B20 Temperature Data on a micro SD Card by Excel
  KinCony Company - https://www.kincony.com
  This program logs temperature data from a DS18B20 sensor
  to an SD card, including the current date and time.
  The date and time can be set via serial commands.
  Serial Command to Set Date and Time:
  DYYYY-MM-DDTHH:MM:SS  (Example: D2024-09-01T20:00:00)
  - Sets the date to September 1, 2024, and the time to 20:00:00.
  Serial Command to Get Current Date and Time:
  current time
  - Returns the current date and time in the format:
    Current Date: YYYY-MM-DD
    Current Time: HH:MM:SS
  current time
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SD.h>
#include <SPI.h>
#include <TimeLib.h>
// Pin assignments
#define ONE_WIRE_BUS 26
#define SD_CS_PIN 5
// DS18B20 sensor setup
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// SD card setup
File dataFile;
  // Start serial communication
  // Start the DS18B20 sensor
  sensors.begin();
  // Start the SD card
  if (!SD.begin(SD_CS_PIN)) {
    Serial.println("SD card initialization failed!");
    return;
  // Open the file for writing
  dataFile = SD.open("/temperature_log.csv", FILE_WRITE);
  if (dataFile) {
    // Write the header
    dataFile.println("Date,Time,Temperature (°C)");
    dataFile.close();
  } else {
    Serial.println("Error opening file for writing");
  // Initialize the time to a default value
  setTime(0, 0, 0, 1, 1, 2020); // Default to Jan 1, 2020 00:00:00
  // Check for serial input
  if (Serial.available()) {
    String input = Serial.readStringUntil('\n');
    // Set the time if the input starts with 'D'
    if (input.startsWith("D")) {
      int year = input.substring(1, 5).toInt();
      int month = input.substring(6, 8).toInt();
      int day = input.substring(9, 11).toInt();
      int hour = input.substring(12, 14).toInt();
      int minute = input.substring(15, 17).toInt();
      int second = input.substring(18, 20).toInt();
      setTime(hour, minute, second, day, month, year);
      Serial.println("Time updated successfully!");
    // Return the current time if the input is "current time"
    else if (input == "current time") {
      String currentDate = String(year()) + "-" + String(month()) + "-" + String(day());
      String currentTime = String(hour()) + ":" + String(minute()) + ":" + String(second());
      Serial.print("Current Date: ");
      Serial.println(currentDate);
      Serial.print("Current Time: ");
      Serial.println(currentTime);
  // Get the current date and time
  String formattedDate = String(year()) + "-" + String(month()) + "-" + String(day());
  String formattedTime = String(hour()) + ":" + String(minute()) + ":" + String(second());
  // Request temperature measurement
  sensors.requestTemperatures();
  float temperatureC = sensors.getTempCByIndex(0);
  // Open the file for appending
  dataFile = SD.open("/temperature_log.csv", FILE_APPEND);
  if (dataFile) {
    // Write the data as a new line
    dataFile.print(formattedDate);
    dataFile.print(",");
    dataFile.print(formattedTime);
    dataFile.println(temperatureC, 2); // 2 decimal places for temperature
    dataFile.close();
    // Print to the Serial Monitor as well
    Serial.print(formattedDate);
    Serial.print(",");
    Serial.print(formattedTime);
    Serial.print(",");
    Serial.println(temperatureC, 2);
  } else {
    Serial.println("Error opening file for appending");
  // Wait for 5 seconds before the next measurement
  delay(5000);
ATF Arduino source code - Save DS18B20 Temperature Data on a micro SD Card by Excel - by admin - 09-02-2024, 03:41 AM
