Tuya adapter V2 arduino source code - RS485 relay controller KC868-H32BS
1. now the Arduino code only work for KinCony's relay board. if you want connect with your own hardware, you need modify Arduino code, don't use chatGPT, suggest you find a software engineer to do that.
2. if you want create your own hardware connection, you need write the software for ESP32 , also you need to create Tuya device in your own Tuya iot platform, they need modify all.
RE: Tuya adapter V2 arduino source code - RS485 relay controller KC868-H32BS - by admin - 09-03-2024, 11:53 PM
