AIO board has failed
(09-13-2024, 12:13 AM)admin Wrote: power supply use DC12v is better. can you check some voltage point on pcb? such as 12V port, 5v pin and 3.3v pin whether work well. there are label on PCB showed voltage. if all point voltage is normal, suggest you replace a new ESP32 module.
which version is the correct one?
AIO board has failed - by telewizard13 - 09-12-2024, 09:06 PM
RE: AIO board has failed - by admin - 09-13-2024, 12:13 AM
RE: AIO board has failed - by telewizard13 - 09-13-2024, 03:10 AM
RE: AIO board has failed - by telewizard13 - 09-13-2024, 02:02 AM
RE: AIO board has failed - by admin - 09-13-2024, 04:36 AM
RE: AIO board has failed - by telewizard13 - 09-13-2024, 10:00 AM
RE: AIO board has failed - by admin - 09-13-2024, 11:22 AM
RE: AIO board has failed - by telewizard13 - 09-17-2024, 02:13 AM
RE: AIO board has failed - by admin - 09-17-2024, 03:53 AM
