10-02-2024, 05:19 PM
Bonjour,
Je viens de regarder le lien et adapter le programme. Il semble que les entrée 32, 33 et 14 étaient configurées en binary_sensor. dans le bas du programme j'ai réussi à configurer une seule des pins en Dallas.
Je ne dois pas encoder le Yaml comme il faut. Pouvez-vous m'aider à définir le bon Yaml at avoir les 3 entrée en configuration température svp ?
Pour Ethernet, que dois-je faire ?
Bien cordialement
Bernard
Programme :
type: esp-idf
wifi:
ssid: !secret wifi_ssid
encryption:
key: "KAMaVIgkKvrw3dsC7KD3/gHHSPCnpZOSUC7JjK0r1qo="
ota:
- platform: esphome
password: "04fad46ba41ed3068d41fad2ed0c0dee"
#ethernet:
# type: LAN8720
# mdc_pin: GPIO23
# mdio_pin: GPIO18
# clk_mode: GPIO17_OUT
# phy_addr: 0
uart:
- id: rs485
tx_pin: GPIO13
rx_pin: GPIO16
baud_rate: 9600
remote_receiver:
number: GPIO2
ignore_strapping_warning: true
remote_transmitter:
number: GPIO15
carrier_duty_percent: 100%
sda: GPIO4
scl:
number: GPIO5
- id: inputs_1_8
address: 0x22
- id: inputs_9_16
address: 0x21
- id: outputs_1_8
address: 0x24
- id: outputs_9_16
address: 0x25
# - platform: gpio
# name: "KC868-A16-HT1"
# pin:
# number: GPIO32
# inverted: true
# - platform: gpio
# name: "KC868-A16-HT2"
# pin:
# number: GPIO33
# inverted: true
# - platform: gpio
# name: "KC868-A16-HT3"
# pin:
# number: GPIO14
# inverted: true
pcf8574: inputs_1_8
pcf8574: inputs_1_8
pcf8574: inputs_1_8
pcf8574: inputs_1_8
pcf8574: inputs_1_8
number: 4
pcf8574: inputs_1_8
number: 5
pcf8574: inputs_1_8
number: 6
pcf8574: inputs_1_8
number: 7
pcf8574: inputs_9_16
number: 4
number: 5
number: 6
number: 7
pcf8574: outputs_1_8
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: outputs_9_16
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
# Config entree 1
one_wire:
pin: GPIO32
- platform: dallas_temp
address: 0x1a0113136655aa28
update_interval: 120s
# Config entree 2
#one_wire:
# - platform: gpio
# pin: GPIO33
#sensor:
# - platform: dallas_temp
# address: 0x1a0113136655aa28
# name: temperature
# update_interval: 120s
# Config entree 3
#one_wire:
# - platform: gpio
# pin: GPIO14
#sensor:
# name: temperature
Bien cordialement
Bernard
Programme :
type: esp-idf
wifi:
encryption:
ota:
- platform: esphome
#ethernet:
# type: LAN8720
# mdc_pin: GPIO23
# mdio_pin: GPIO18
# phy_addr: 0
uart:
- id: rs485
tx_pin: GPIO13
rx_pin: GPIO16
baud_rate: 9600
remote_receiver:
number: GPIO2
remote_transmitter:
number: GPIO15
sda: GPIO4
scl:
number: GPIO5
- id: inputs_1_8
address: 0x22
- id: inputs_9_16
address: 0x21
- id: outputs_1_8
address: 0x24
- id: outputs_9_16
address: 0x25
# - platform: gpio
# pin:
# number: GPIO32
# inverted: true
# - platform: gpio
# pin:
# number: GPIO33
# inverted: true
# - platform: gpio
# pin:
# number: GPIO14
# inverted: true
pcf8574: inputs_1_8
pcf8574: inputs_1_8
pcf8574: inputs_1_8
pcf8574: inputs_1_8
pcf8574: inputs_1_8
number: 4
pcf8574: inputs_1_8
number: 5
pcf8574: inputs_1_8
number: 6
pcf8574: inputs_1_8
number: 7
number: 4
number: 5
number: 6
number: 7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
# Config entree 1
one_wire:
pin: GPIO32
# Config entree 2
#one_wire:
# - platform: gpio
# pin: GPIO33
#sensor:
# name: temperature
# Config entree 3
#one_wire:
# - platform: gpio
# pin: GPIO14
#sensor:
# name: temperature
