Sensor DHT22 on modul A16
dear admin,
I am using KC868-A16 and I need to connect temperature and humidity sensors to 3 1-Wire inputs. I connected DS18B20 sensors to pins "GPIO32" and "GPIO33" and DHT22 sensor (/AM2302) to pin "GPIO14". When installing the module in HomeAssistant add-on ESPHome, DS18B20 sensors are loaded correctly, but DHT22 sensor is not found. I tried two DHT22 sensors with the same result.
This is the code in YAML
one_wire:
    pin: GPIO32
    pin: GPIO33
    pin: GPIO14
  - platform: dallas_temp
    address: 0x773ce1d458ac1a28
    update_interval: 120s
    one_wire_id: one_wire1
    address: 0xfd3ce1d4432b6528
    one_wire_id: one_wire2
The attached image is a screenshot from the installation.
Please could you help me? Where am I making a mistake?
Is this the correct code to get values from DHT22?
- platform: dht
    model: DHT22
    one_wire_id: one_wire3
    temperature:
    humidity:
    update_interval: 30s
Sensor DHT22 on modul A16 - by Brouk - 11-20-2024, 12:16 PM
RE: Sensor DHT22 on modul A16 - by admin - 11-20-2024, 11:11 PM
RE: Sensor DHT22 on modul A16 - by Brouk - 11-22-2024, 09:11 PM
RE: Sensor DHT22 on modul A16 - by admin - 11-22-2024, 10:39 PM
RE: Sensor DHT22 on modul A16 - by Brouk - 11-23-2024, 11:23 AM
RE: Sensor DHT22 on modul A16 - by admin - 11-23-2024, 11:43 AM
RE: Sensor DHT22 on modul A16 - by Brouk - 11-24-2024, 10:44 AM
RE: Sensor DHT22 on modul A16 - by admin - 11-24-2024, 01:17 PM
RE: Sensor DHT22 on modul A16 - by Brouk - 12-04-2024, 05:21 PM
RE: Sensor DHT22 on modul A16 - by admin - 12-07-2024, 05:41 AM
RE: Sensor DHT22 on modul A16 - by Brouk - 12-13-2024, 05:04 PM
RE: Sensor DHT22 on modul A16 - by admin - 12-14-2024, 01:15 AM
RE: Sensor DHT22 on modul A16 - by twostar - 02-11-2025, 08:41 AM
RE: Sensor DHT22 on modul A16 - by admin - 02-11-2025, 10:39 AM
RE: Sensor DHT22 on modul A16 - by twostar - 02-13-2025, 12:59 AM
RE: Sensor DHT22 on modul A16 - by admin - 02-13-2025, 02:54 AM
RE: Sensor DHT22 on modul A16 - by twostar - 02-13-2025, 02:56 AM
RE: Sensor DHT22 on modul A16 - by admin - 02-13-2025, 05:07 AM
RE: Sensor DHT22 on modul A16 - by twostar - 02-13-2025, 08:22 AM
RE: Sensor DHT22 on modul A16 - by admin - 02-13-2025, 08:42 AM
RE: Sensor DHT22 on modul A16 - by twostar - 02-13-2025, 08:48 AM
RE: Sensor DHT22 on modul A16 - by twostar - 02-13-2025, 10:24 AM
RE: Sensor DHT22 on modul A16 - by admin - 02-13-2025, 10:25 AM
RE: Sensor DHT22 on modul A16 - by twostar - 02-13-2025, 10:30 AM
RE: Sensor DHT22 on modul A16 - by twostar - 02-14-2025, 09:35 AM
RE: Sensor DHT22 on modul A16 - by admin - 02-14-2025, 12:43 PM
RE: Sensor DHT22 on modul A16 - by twostar - 02-14-2025, 01:23 PM
