All outputs turn off every once in a while
1. all these functions can set in yaml if you using ESPHome.
2. i suggest you try to download KCS firmware to your board. Then integrate KC868-A16 to home assistant by MQTT. you can check whether work well. Just want to know whether is the software problem or hardware problem.
RE: All outputs turn off every once in a while - by admin - 12-02-2024, 11:02 PM
