change wake up name
#19
(12-20-2024, 12:52 PM)admin Wrote: when i have free time, will update the yaml for use these sensor. the last one, VALVE is not a sensor, you can connect with relay output port to drive it.
Ok, Thank you.
I have just received my b16m and f24 today all installed all working ok .
I want to get my door access keypad put on to the B16m using wiegand , I have installed the B16m to esphome to do this as you mentioned before I cannot use this if I have Kcs firmware installed is that correct?, what 2 gpios do I use on the B16m for the 2 data wires from the access control keypad?
Thanks for your support much appreciated.
change wake up name - by gal - 12-13-2024, 02:29 PM
RE: change wake up name - by admin - 12-14-2024, 01:04 AM
RE: change wake up name - by gal - 12-14-2024, 10:40 PM
RE: change wake up name - by admin - 12-15-2024, 06:17 AM
RE: change wake up name - by gal - 12-15-2024, 12:58 PM
RE: change wake up name - by admin - 12-16-2024, 12:06 AM
RE: change wake up name - by gal - 12-16-2024, 08:19 AM
RE: change wake up name - by admin - 12-16-2024, 11:14 AM
RE: change wake up name - by gal - 12-17-2024, 09:14 AM
RE: change wake up name - by admin - 12-17-2024, 09:21 AM
RE: change wake up name - by gal - 12-17-2024, 04:23 PM
RE: change wake up name - by admin - 12-17-2024, 11:38 PM
RE: change wake up name - by gal - 12-18-2024, 07:36 AM
RE: change wake up name - by admin - 12-19-2024, 02:10 AM
RE: change wake up name - by gal - 12-19-2024, 09:34 PM
RE: change wake up name - by admin - 12-20-2024, 12:15 AM
RE: change wake up name - by gal - 12-20-2024, 08:18 AM
RE: change wake up name - by admin - 12-20-2024, 12:52 PM
RE: change wake up name - by gal - 12-20-2024, 10:25 PM
RE: change wake up name - by admin - 12-20-2024, 11:35 PM
RE: change wake up name - by gal - 12-21-2024, 05:58 PM
RE: change wake up name - by admin - 12-22-2024, 02:43 AM
RE: change wake up name - by gal - 12-22-2024, 09:01 AM
RE: change wake up name - by admin - 12-22-2024, 11:04 AM
RE: change wake up name - by gal - 12-22-2024, 11:11 AM
RE: change wake up name - by admin - 12-22-2024, 11:41 PM
RE: change wake up name - by gal - 12-23-2024, 10:26 AM
RE: change wake up name - by admin - 12-23-2024, 10:49 AM
RE: change wake up name - by admin - 12-30-2024, 06:43 AM
