01-18-2025, 09:17 AM
(01-18-2025, 12:13 AM)admin Wrote: do you use ESPHome or KCS firmware?
can you change a ethernet cable and router's port.
I got a feeling that the board collect some voltage spikes from the electrical system. I already grounded the din rail, it helped a little, but randomly still happens.
I'll try to swap cable and switchport, maybe I should use CAT6 shielded cable?
Its on ESPHome, LAN config is the folllowing:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
