Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command
ESPHome configure for KC868-A8:
function list:
1. 8 relay output
2. 8 switch input trigger relay output by on_press action
3. monitor 2 channel analog input for DC
4. TEMP-1 port: 2 channel DS18B20 temperature sensor use by 1 ports, actually, you can connect multi DS18B20 by one wire.
5. TEMP-4 port: WS2812B LED strip for 1 meter (30 LEDs)
6. network by Ethernet cable
  platform: ESP32
ota:
  password: "bfb55afbf347b27a4bda0a1d36ee994f"
web_server:
  port: 80
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  - id: 'pcf8574_hub_output'
    address: 0x24
  - id: 'pcf8574_hub_input'
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_output
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: OUTPUT
      # Use pin number 0
      mode: OUTPUT
      # Use pin number 0
      mode: OUTPUT
      # Use pin number 0
      mode: OUTPUT
      # Use pin number 0
      number: 4
      mode: OUTPUT
      # Use pin number 0
      number: 5
      mode: OUTPUT
      # Use pin number 0
      number: 6
      mode: OUTPUT
      # Use pin number 0
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_input
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch1
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch2
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch3
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch4
      # Use pin number 0
      number: 4
      inverted: false
    on_press:
      then:
        - switch.toggle: switch5
      # Use pin number 0
      number: 5
      inverted: false
    on_press:
      then:
        - switch.toggle: switch6
      # Use pin number 0
      number: 6
      inverted: false
    on_press:
      then:
        - switch.toggle: switch7
      # Use pin number 0
      number: 7
      inverted: false
    on_press:
      then:
        - switch.toggle: switch8
dallas:
  - pin: GPIO14
    update_interval: 5s
  - platform: dallas
    address: 0xE701202C5ADED628
  - platform: dallas
    address: 0xBE012115DCBEBC28
  - platform: adc
    pin: GPIO34
    update_interval: 5s
    attenuation: 11db
  - platform: adc
    pin: GPIO35
    update_interval: 5s
    attenuation: 11db
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO33    # Pin Define connected with LED strip
    num_leds: 150  #LEDs number
    rgb_order: GRB
    effects:
      - addressable_rainbow:        ##defined 7 effects styles
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
KC868-A8/A4 http command list for third party software integration:
read relay state:
http://192.168.1.199/switch/switch1
control relay:
http://192.168.1.199/switch/switch1/turn_on
http://192.168.1.199/switch/switch1/turn_off
http://192.168.1.199/switch/switch1/toggle
read DI state:
http://192.168.1.199/binary_sensor/input1
read temperature:
http://192.168.1.199/sensor/temperature_1
read analog input:
http://192.168.1.199/sensor/analog-in1
read LED strip:
http://192.168.1.199/light/light_strip
control LED strip:
http://192.168.1.199/light/light_strip/turn_on
http://192.168.1.199/light/light_strip/turn_off
http://192.168.1.199/light/light_strip/turn_toggle
debug send command for TEST example: curl -X POST http://192.168.1.199/switch/switch1/toggle
Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command - by admin - 11-02-2021, 12:38 AM
