How to measure current using Analog Inputs on KC868-A16?
thank you for the quick response.
I was afraid that my plan would not work, but buying the M30 module for measuring current on one or two phases does not make sense.
can I connect a device like "Split Core Current Transmitter 0-500A AC DC Hall Current Sensor Transducer 20mm Hole 0-10V 4-20mA RS485 Current Transmitter" (eg: https://vi.aliexpress.com/item/1005007120648979.html ) in the "0-5V Output" variant to the analog input A16?
if yes, is the code below correct for this purpose?
  - platform: adc
    pin: 36
    update_interval: 1s
    attenuation: 12db
and why is the voltage 0.14V displayed on an input that is not occupied? is this OK, or is there a defect in the analog input?
regards
RE: How to measure current using Analog Inputs on KC868-A16? - by Brouk - 02-12-2025, 06:48 PM
