Using 12v on Digital Input
#17
(03-09-2025, 01:05 AM)administración Wrote: Entrada corta con GND, eso significa "verdadero" lógico.
Si conecta con 24v a ENTRADA, eso significa "falso" lógico.
Entonces, 0v y 24v son estados lógicos diferentes.
Sí, son estados lógicos diferentes, pero no es PNP, solo puedes usar NPN, ¡lo cual está bien! Pero en la mayor parte de la industria en Europa se usa PNP. Gracias por la aclaración.
(03-09-2025, 01:05 AM)admin Wrote: input short with GND, that means logical "true".
if you connect with 24v to INPUT, that mean logical "false".
so 0v and 24v are different logical state.
yes they are different logic states, but it is not PNP, you can only use NPN, which is fine!!! but for most of the industry in europe PNP is used. thanks for the clarification.
Using 12v on Digital Input - by DW1 - 01-05-2025, 12:08 AM
RE: Using 12v on Digital Input - by admin - 01-05-2025, 01:12 AM
RE: Using 12v on Digital Input - by osis - 01-10-2025, 09:34 AM
RE: Using 12v on Digital Input - by jorgete - 03-07-2025, 07:06 PM
RE: Using 12v on Digital Input - by osis - 01-10-2025, 09:35 AM
RE: Using 12v on Digital Input - by osis - 01-10-2025, 09:37 AM
RE: Using 12v on Digital Input - by admin - 01-11-2025, 01:57 AM
RE: Using 12v on Digital Input - by osis - 01-12-2025, 05:27 PM
RE: Using 12v on Digital Input - by admin - 01-13-2025, 12:42 AM
RE: Using 12v on Digital Input - by osis - 01-13-2025, 02:13 PM
RE: Using 12v on Digital Input - by admin - 01-13-2025, 11:14 PM
RE: Using 12v on Digital Input - by osis - 01-14-2025, 10:54 AM
RE: Using 12v on Digital Input - by admin - 01-14-2025, 11:43 AM
RE: Using 12v on Digital Input - by admin - 03-08-2025, 04:02 AM
RE: Using 12v on Digital Input - by jorgete - 03-08-2025, 07:34 PM
RE: Using 12v on Digital Input - by admin - 03-09-2025, 01:05 AM
RE: Using 12v on Digital Input - by jorgete - 03-09-2025, 08:19 AM
RE: Using 12v on Digital Input - by admin - 03-09-2025, 01:31 PM
RE: Using 12v on Digital Input - by jorgete - 03-17-2025, 04:39 PM
RE: Using 12v on Digital Input - by admin - 03-18-2025, 12:29 AM
