KC868-A4 ,RS232 can not communicate with Max232
(11-15-2021, 10:57 AM)admin Wrote: if you want to test RS232, you just use a USB-RS232 cable connect board with PC, you can send and receive command.
THank  you ,I  think  as  the  same  as  I  done  by  the   program  to  test  rs232  port  is  working  or  not  :
#define RXD2 16
#define TXD2 17
  // Note the format for setting a serial port is as follows: Serial2.begin(baud-rate, protocol, RX pin, TX pin);
  //Serial1.begin(9600, SERIAL_8N1, RXD2, TXD2);
  Serial2.begin(300, SERIAL_8N1, RXD2, TXD2);
  Serial.println("Serial Txd is on pin: "+String(TX));
  Serial.println("Serial Rxd is on pin: "+String(RX));
/*void loop() {
  //Choose Serial1 or Serial2 as required
  if (Serial.available())
    Serial2.write(Serial.read());
  while (Serial2.available())
    Serial.write(Serial2.read());
  delay(500);
void loop()
  Serial2.print("hello");
  Serial2.write("hellowrite");
  Serial.println(String(Serial2.readString()));  //ทดสอบ port rs232 โดยการส่งค่าwrite(hellowwrite) แล้วอ่านค่ากลับ  read
                                              //ผ่านทาง serial2 (Tx ขา 2 ,Rx ขา 3 ต่อกัน และ Tx ต่อ LED ,R 1K แสดงติดๆดับๆ
  Serial.println("Tested");
  delay(2000);
RE: KC868-A4 ,RS232 can not communicate with Max232 - by Nantawit - 11-15-2021, 04:06 PM
