KinCony B8M ESP32-S3 Smart Controller released
KinCony B8M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 8 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B8M include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B8M have I2C bus extender and RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B8M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. B8M support Apple HomeKit, easy to use directly. Support save state LOG to SD Card. It use by local RTC clock, use timer work without internet. B8M support to use KinCony cloud server service, so that you can remote control and monitor your device by internet using mobile phone or computer web browser. note: (buy from KinCony Official Shop have KinCony cloud server 2 years free)
[Image: B8M_1.jpg]
Model No. KinCony B8M
Description: KinCony 8 Channel ESP32-S3 Smart Controller – B8M
Power supply: 12-24V DC
Size:
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD,I2C,Tuya Module
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
8CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
8CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
free GPIO: 3CH (without pull-up resistance on PCB, connect with ESP32 pin directly)
[Image: B8M_6.jpg]
KinCony B8M ESP32-S3 Smart Controller released - by admin - 06-21-2025, 04:07 AM
