[arduino code examples for T128M]-03 RS485 communication test
* RS485 Communication Test with Direction Control (SP3485EEN)
* The TXD pin is defined as GPIO 13, RXD is GPIO 21, and EN is GPIO 14.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 21     // RS485 Receive
#define RS485_TXD 13     // RS485 Transmit
#define RS485_EN  14     // RS485 Direction control (High: Send, Low: Receive)
// Create a hardware serial object on UART1
  while (!Serial);
  // Set RS485 direction control pin
  pinMode(RS485_EN, OUTPUT);
  digitalWrite(RS485_EN, LOW); // Start in receive mode
  // Initialize RS485 serial communication
  Serial.println("RS485 Test Start (with direction control)");
  // Prepare the message to send
  String message = "Hello from KinCony T128M!";
  // Switch to transmit mode
  digitalWrite(RS485_EN, HIGH);
  delay(2); // Short delay to allow driver to switch
  // Send the message
  rs485Serial.println(message);
  rs485Serial.flush(); // Wait for transmission to complete
  // Switch back to receive mode
  Serial.println("Message sent. Waiting for response...");
  // Wait for a response (up to 1 second)
  unsigned long startTime = millis();
  while (millis() - startTime < 1000) {
      String receivedMessage = "";
        char c = rs485Serial.read();
        receivedMessage += c;
      // Print the received message
      Serial.print("Received: ");
      break;
  delay(2000);
arduino ino file download:
.zip   3-RS485-Test.zip (Size: 1.02 KB / Downloads: 657)
.zip   3-RS485-Test.ino.merged.zip (Size: 186.66 KB / Downloads: 707)
[arduino code examples for T128M]-03 RS485 communication test - by admin - 06-23-2025, 05:36 AM
