12-05-2020, 12:47 PM
if you use our relay controller and the switch terminal board, you should replace your old wall switch panel with self-reset wall switch panel, that like buttons. just click button for a signal to relay controller, the switch panel state will not locked for ON/OFF. so every time just click the panel for ON/OFF, not need tell relay controller now the state is ON or OFF, when click the button, relay controller will change the state, like ON->OFF, OFF->ON. You also not need to use relay controller's input for switch, that's for sensor use.
There are two way for control the relays to only stay closed for a specific length of time like ON->30s->OFF.
A. use phone app to create the "SCENE" mode, make 1 action for relay ON, delay 30 seconds, relay OFF. this need controller connect with cloud server by internet.
B. use KC868-COL logical controller, when set the IFTTT command , relay ON,delay 30s, relay OFF save to KC868-COL, it will automatic control relay controller locally without internet. Way A, if internet is broken, the function will be invalid.
