ESP32: ETH + RELAY
I see the relay 1 is 15 pin and relay 2 pin is 2 here:
https://www.kincony.com/forum/showthread.php?tid=2691
well, I flashed the ESP32 using idd.py and I build this code and works fine, but is using wifi, i need to work with ethernet, if someone can helps me I really appreciated:
PHP Code:
#include <string.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_netif.h"
#include "esp_http_server.h"
#include "driver/gpio.h"
// Wi-Fi credentials
#define WIFI_SSID "WIFI_NAME"
#define WIFI_PASS "WIFI_PASSWORD"
// GPIOs for relays
#define RELAY1_GPIO GPIO_NUM_15
#define RELAY2_GPIO GPIO_NUM_2
static const char *TAG "relay_server";
// Relay control
static void set_relay(int relay_numbool on) {
    gpio_num_t gpio = (relay_num == 1) ? RELAY1_GPIO RELAY2_GPIO;
    gpio_set_level(gpioon 1);  // Active LOW
// HTTP Handlers
esp_err_t relay1_on_handler(httpd_req_t *req) {
    set_relay(1false);
    httpd_resp_send(req"Relay 1 ON"HTTPD_RESP_USE_STRLEN);
    return ESP_OK;
esp_err_t relay1_off_handler(httpd_req_t *req) {
    set_relay(1true);
    httpd_resp_send(req"Relay 1 OFF"HTTPD_RESP_USE_STRLEN);
    return ESP_OK;
esp_err_t relay2_on_handler(httpd_req_t *req) {
    set_relay(2false);
    httpd_resp_send(req"Relay 2 ON"HTTPD_RESP_USE_STRLEN);
    return ESP_OK;
esp_err_t relay2_off_handler(httpd_req_t *req) {
    set_relay(2true);
    httpd_resp_send(req"Relay 2 OFF"HTTPD_RESP_USE_STRLEN);
    return ESP_OK;
esp_err_t root_handler(httpd_req_t *req) {
    const charresp_str =
        "ESP32 Relay Control:\n"
        "/relay1/on  or /relay1/off\n"
        "/relay2/on  or /relay2/off\n";
    httpd_resp_send(reqresp_strHTTPD_RESP_USE_STRLEN);
    return ESP_OK;
// HTTP Server
httpd_handle_t start_webserver(void) {
    httpd_config_t config HTTPD_DEFAULT_CONFIG();
    httpd_handle_t server NULL;
    if (httpd_start(&server, &config) == ESP_OK) {
        httpd_uri_t root = {
            .uri       "/",
            .method    HTTP_GET,
            .handler   root_handler,
            .user_ctx  NULL
        httpd_uri_t relay1_on = {
            .uri       "/relay1/on",
            .method    HTTP_GET,
            .handler   relay1_on_handler,
            .user_ctx  NULL
        httpd_uri_t relay1_off = {
            .uri       "/relay1/off",
            .method    HTTP_GET,
            .handler   relay1_off_handler,
            .user_ctx  NULL
        httpd_uri_t relay2_on = {
            .uri       "/relay2/on",
            .method    HTTP_GET,
            .handler   relay2_on_handler,
            .user_ctx  NULL
        httpd_uri_t relay2_off = {
            .uri       "/relay2/off",
            .method    HTTP_GET,
            .handler   relay2_off_handler,
            .user_ctx  NULL
        httpd_register_uri_handler(server, &root);
        httpd_register_uri_handler(server, &relay1_on);
        httpd_register_uri_handler(server, &relay1_off);
        httpd_register_uri_handler(server, &relay2_on);
        httpd_register_uri_handler(server, &relay2_off);
    return server;
// Wi-Fi event handler
static void wifi_event_handler(voidargesp_event_base_t event_base,
                               int32_t event_idvoidevent_data) {
    if (event_id == WIFI_EVENT_STA_START) {
        esp_wifi_connect();
    } else if (event_id == WIFI_EVENT_STA_DISCONNECTED) {
        esp_wifi_connect();
    } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
        ESP_LOGI(TAG"Connected with IP");
        start_webserver();
// Initialize Wi-Fi
void wifi_init(void) {
    esp_netif_init();
    esp_event_loop_create_default();
    esp_netif_create_default_wifi_sta();
    wifi_init_config_t cfg WIFI_INIT_CONFIG_DEFAULT();
    esp_wifi_init(&cfg);
    esp_event_handler_register(WIFI_EVENTESP_EVENT_ANY_ID, &wifi_event_handlerNULL);
    esp_event_handler_register(IP_EVENTIP_EVENT_STA_GOT_IP, &wifi_event_handlerNULL);
    wifi_config_t wifi_config = {
        .sta = {
            .ssid WIFI_SSID,
            .password WIFI_PASS,
    esp_wifi_set_mode(WIFI_MODE_STA);
    esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config);
    esp_wifi_start();
// GPIO setup
void relay_gpio_init() {
    gpio_config_t io_conf = {
        .pin_bit_mask = (1ULL << RELAY1_GPIO) | (1ULL << RELAY2_GPIO),
        .mode GPIO_MODE_OUTPUT,
        .pull_up_en 0,
        .pull_down_en 0,
        .intr_type GPIO_INTR_DISABLE,
    gpio_config(&io_conf);
    // Default state: OFF
    gpio_set_level(RELAY1_GPIO0);
    gpio_set_level(RELAY2_GPIO0);
void app_main(void) {
    ESP_ERROR_CHECK(nvs_flash_init());
    relay_gpio_init();
    wifi_init();
To enable disable relays (you can see the IP in the logs):
http://IP/relay1/on
http://IP/relay1/off
http://IP/relay2/on
http://IP/relay2/off
ESP32: ETH + RELAY - by zital - 07-03-2025, 06:47 AM
RE: ESP32: ETH + RELAY - by admin - 07-03-2025, 07:59 AM
RE: ESP32: ETH + RELAY - by zital - 07-03-2025, 08:38 PM
RE: ESP32: ETH + RELAY - by zital - 07-03-2025, 10:00 PM
RE: ESP32: ETH + RELAY - by admin - 07-04-2025, 01:03 AM
RE: ESP32: ETH + RELAY - by zital - 07-04-2025, 10:16 AM
RE: ESP32: ETH + RELAY - by admin - 07-05-2025, 01:42 AM
RE: ESP32: ETH + RELAY - by zital - 07-05-2025, 06:39 PM
