thanks for your information. the board is good. but this board have two side of relay output teminal. if install into Power Distribution Box. relay controller output wire need go to this board's right green ports. the 17-32 relay outputs' wire need covered all board go through to bottom of box. only have this problem.
we are plan to design a new extend relay module, maybe based on 8 channel, 16 channel, 32 channel.
but the most important is we will install manual button on the extend relay board. if smart controller is bad, people can use button for ON/OFF on the board, although KinCony's smart controller will not fail easily.
these are my idea, if you have some suggestions, welcome tell us. we will consider your design idea.
