Problem with A16 inputs 9-16
On my A16, inputs 9-16 show all on, while nothing is physically connected.
I tested with a multimeter and there is +12V between GND and any input pin. It's the same on Inputs 1-8 btw, but they work just fine.
My device is connected to Home Assistant as ESPHome, below is the programmed YAML's relevant parts. I compared this with the recommended settings and it looks pretty much the same. Any clue what is wrong, or am I missing something in the config?
  sda: 4
  scl: 5
    address: 0x24
    pcf8575: false
    address: 0x25
    pcf8575: false
    address: 0x22
    pcf8575: false
    address: 0x21
    pcf8575: false
#skipped inputs 1-8, they work fine
      pcf8574: pcf8574_hub_in_2
# and so on for 11-16...
Problem with A16 inputs 9-16 - by jarekD - 11-23-2025, 07:25 PM
RE: Problem with A16 inputs 9-16 - by admin - 11-23-2025, 10:54 PM
RE: Problem with A16 inputs 9-16 - by jarekD - 11-24-2025, 05:19 PM
RE: Problem with A16 inputs 9-16 - by admin - 11-24-2025, 11:17 PM
RE: Problem with A16 inputs 9-16 - by jarekD - 11-25-2025, 12:28 AM
RE: Problem with A16 inputs 9-16 - by admin - 11-25-2025, 01:30 AM
RE: Problem with A16 inputs 9-16 - by jarekD - 11-25-2025, 06:06 PM
RE: Problem with A16 inputs 9-16 - by admin - 11-25-2025, 11:26 PM
