01-13-2026, 08:07 AM
Thanks for your suggestion.
1. KC868-A8v3 power supply both support DC12-24V. it use by 5v relay coin.
2. you said: "Summing up my requirements for the ideal cabinet 230V actor:"
what's "23V outputs: 10 / 16 A relays"? Do you want DC23v output terminal?
3. Could you consider replacing the "permanent switches" with buttons and program a software-behaviour like "hold them for momentary-override" or "double click for permanent on/off"?
--> Now the digital input ports use by wall switch buttons. manual control button use by "permanent switches", because of it can work without firmware or software, so that any time it can control relay on/off physically, because it control relay's coin directly.
