CT Clamp Compatibility
#12
(08-09-2026, 10:32 PM)admin Wrote: "voltage" type CT sensor also can work.
I am back from vacation.
I will contact you via WhatsApp.
Just to recall:
  1. I have YMDC SCT013 20A/1V class: 1(and 50A/1v).
  2. I do not have problem with mini-jack plugs. I connect SCT's jack into the plug and then into the appropriate terminals of N30. I checked the connections and all works fine. This is not the problem.
  3. I tested the SCT on the wire of an electric kettle.
    I measured the current: 8.2A (voltage is 230V), but no readout in the logs of ESP32-generated firmware though. I measure the voltage on the terminals of N30. It swayed way beyond 1V.
Looking for help.
Stan
CT Clamp Compatibility - by threeofseven - 04-16-2024, 10:54 AM
RE: CT Clamp Compatibility - by admin - 04-16-2024, 12:18 PM
RE: CT Clamp Compatibility - by kiloptero - 06-22-2024, 11:12 PM
RE: CT Clamp Compatibility - by admin - 06-23-2024, 12:23 AM
RE: CT Clamp Compatibility - by Stanb - 08-08-2026, 10:43 PM
RE: CT Clamp Compatibility - by Stanb - 08-09-2026, 09:39 AM
RE: CT Clamp Compatibility - by admin - 08-08-2026, 11:56 PM
RE: CT Clamp Compatibility - by admin - 08-09-2026, 11:32 AM
RE: CT Clamp Compatibility - by Stanb - 08-09-2026, 02:52 PM
RE: CT Clamp Compatibility - by Stanb - 08-09-2026, 08:52 PM
RE: CT Clamp Compatibility - by Stanb - 10-24-2026, 12:20 PM
RE: CT Clamp Compatibility - by admin - 08-09-2026, 10:32 PM
RE: CT Clamp Compatibility - by Stanb - 08-16-2026, 01:12 PM
RE: CT Clamp Compatibility - by admin - 08-16-2026, 11:08 PM
RE: CT Clamp Compatibility - by admin - 10-25-2026, 12:21 AM
