Understand Configuration For Own Software
#22
(03-08-2022, 02:05 PM)admin Wrote: let your ethernet and wifi by different work mode. such as one is TCP Server, one is MQTT or TCP Client.
https://www.kincony.com/forum/showthread.php?tid=1739    here is how to develop with KC868-COLB , this link useful for you.
thank you, about hex comand for digital input on COLB non problem and it's work, I need just do understand the page about rs232 and rs485 for check switch terminal board, can you translate please (or if is possible to have a table with all command code )
about to config ethernet mode in tcp client I will send you picure because withe led it's on only in MQTT mode
thanks again
RE: Understand Configuration For Own Software - by Dm81 - 03-10-2022, 08:16 AM
