03-12-2022, 02:41 PM
(03-12-2022, 01:41 PM)admin Wrote: switch terminal board not support read input from tcp. if you use 2pcs KC868-COLB, let 32 channel wall switch connect to COLB's digital input, then you can do what you needed, because you can read the DI then send command to control relay.
Ok, with swithc terminal board is not possible to mange input, input 1 control relay1 on H32B and so on... now it' clear... I'm not happy but it's clear
About RS485 is ther possibility tuo send/receie command throug tcp on colb? from your software is possible, in this case can I have command?
thank you
