05-02-2022, 06:00 AM
(05-02-2022, 12:45 AM)admin Wrote: there are some GPIOs on the KC868-AG PCB board. you will see text on the pcb, some are "IOxx", some are "Ixx" . "IOxx" means the pin you can use for "input" and "ouptut", if "Ixx" only use for "input" , not for "output".
so make sure you have using the "IOxx" for IR extend, because IR signal is "output" type.
Thanks it's what I did ! I tried the GPIO 14 and the 21 but no success ! How would you wire the IR emitter on the GPIO ? I have respected the polarity of LED and tried between 3.3V and GPIO, and also between GND and GPIO but LED never lights
