KC868-UAIR ESPHOME Config for IR and RF
#19
OK! Many thanks
(05-12-2022, 12:53 PM)admin Wrote: here is config file for IR receiver.
OK I've now spent some time putting all the devices into the config and the IR and RF receivers stop working as soon as I add one of the lights.  So my config is shown below.  If I uncomment the one light shown in this, no IR or RF codes are display and this was my original problem.  So I think with your help this issue has been narrowed down to some conflict with the LED config and the IR/RF receivers.  Any thoughts on the next steps appreciated!
    type: arduino
ota:
  password: "xxx"
wifi:
  ssid: !secret wifi_ssid
  domain: .lan
  ap:
    ssid: "Kc868-Uair Fallback Hotspot"
    password: "xxx"
captive_portal:
remote_receiver:
  - id: RF_Receiver
    pin: 13
    dump:
      - rc_switch
  # Settings to optimize recognition of RF devices
    tolerance: 50%
    filter: 250us
    idle: 4ms
    buffer_size: 2kb
  - id: IR_Receiver
      number: 19
      inverted: True
    dump:
      - panasonic
    pin: 26
# Dallas example configuration entry
dallas:
  - pin: GPIO27
    update_interval: 60s
# Individual sensors - change address to be yours by observing ESPHOME console and looking for sensor discovery
  - platform: dallas
    address: 0x070000000d564b28  # your DS18B20 address
    name: "internal Temperature"
# Added i2c
# follow configure use for DS18B20 temperature sensor, SHT30 temperature and humidity sensor. WS2812B RGB LEDs.
  sda: 4
  scl: 16
# Added First Lights
#light:
#  - platform: fastled_clockless
#    chipset: WS2812B
#    pin: GPIO32    # Pin Define connected with LED strip
#    num_leds: 4  #LEDs number
#    rgb_order: GRB
#    name: "Uair-Bottom-LED"# Example configuration entry
#    effects:
#      - addressable_rainbow:        ##defined 7 effects styles
#      - addressable_color_wipe:
#      - addressable_scan:
#      - addressable_twinkle:
#      - addressable_random_twinkle:
#      - addressable_fireworks:
#      - addressable_flicker:
RE: KC868-UAIR ESPHOME Config for IR and RF - by dmshimself - 05-13-2022, 05:41 AM
