  • 1 Vote(s) - 5 Average
[Arduino IDE of KC868-E16S]--#00-KC868-E16S-configure for ESPhome
Thumbs Up
  platform: ESP32
  sda: 16
  scl: 15
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
#  manual_ip:
#    static_ip: 192.168.1.199
#    gateway: 192.168.1.1
#    subnet: 255.255.255.0
    address: 0x21
    address: 0x25
    address: 0x22
    address: 0x24
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_2
      number: 4
      number: 5
      number: 6
      number: 7
[Arduino IDE of KC868-E16S]--#00-KC868-E16S-configure for ESPhome - by admin - 05-17-2022, 12:45 AM
