05-21-2022, 01:54 AM
(05-21-2022, 12:28 AM)admin Wrote: config file i have tested, no problem, you can change another USB cable for a test. maybe not enough current for USB.
Do you mean you have tested the config file I uploaded or do you mean you tested using the config you supplied?
The USB cable is the same one I have been using for ages, plugged into an apple adapter. It's not a power supply issue. Prior to your suggested config change, I could upload new configs just fine with exactly the same environment, so it's definitely something that happened as part of uploading the new config you recommended with the changes to the 'method'.
Keep in mind the upload worked first time just fine when I first used your config. After the upload, the single bottom LED was set on and also the vertical to on and red. It was only after that sequence no further uploads could be done.
How can I recover from this situation?
