Lesson16 - integrate ZigBee device to home assistant by Zigbee2MQTT
Hello
I receive an error at step of zigbee start.
I have rechecked the configuration, mqtt server/user/pass, activation of usb. The donglle has a green flash when I connect to usb for a few seconds and then remains green continously on for almost a minute .
[17:41:13] INFO: Handing over control to Zigbee2mqtt Core ...
> zigbee2mqtt@1.25.2 start
> node index.js
Zigbee2MQTT:info 2022-06-16 17:41:19: Logging to console and directory: '/config/zigbee2mqtt/log/2022-06-16.17-41-19' filename: log.txt
Zigbee2MQTT:info 2022-06-16 17:41:19: Starting Zigbee2MQTT version 1.25.2 (commit #unknown)
Zigbee2MQTT:info 2022-06-16 17:41:19: Starting zigbee-herdsman (0.14.34)
Zigbee2MQTT:error 2022-06-16 17:41:20: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-06-16 17:41:20: Failed to start zigbee
Zigbee2MQTT:error 2022-06-16 17:41:20: Check https://www.zigbee2mqtt.io/guide/install...start.html for possible solutions
Zigbee2MQTT:error 2022-06-16 17:41:20: Exiting...
Zigbee2MQTT:error 2022-06-16 17:41:20: Error: spawn udevadm ENOENT
at Process.ChildProcess._handle.onexit (node:internal/child_process:283:19)
at onErrorNT (node:internal/child_process:478:16)
at processTicksAndRejections (node:internal/process/task_queues:83:21)
RE: Lesson16 - integrate ZigBee device to home assistant by Zigbee2MQTT - by bogdan_0 - 06-16-2022, 02:52 PM
