Lesson4 - Install Home Assistant Operating System
minor note need to be add after last step for the case that i had:
- after flash complete, change the boot jumper for startup system.
- when power on, after about 3 minutes
-you can use http://homeassistant.local:8123/ or http://X.X.X.X:8123 to login home assistant.
-make sure your computer and KC868-Server connect with same router, in one local network.
- if you still can't see homeassistance on ip advanced scan, just reset the button S2 of the server ( Ethernet rest )
then will appear homeasistant and ip see attached for this example: http://homeasistsance:8123 or http://192.168.1.8:8123
RE: Lesson4 - Install Home Assistant Operating System - by ahmed - 07-28-2022, 12:19 AM
