Switch terminal board H16B relay default controll
Hi
I would like to have a wall switch status monitored in Home Assistant using Node Red to do automation.  I have this configured and working as per the 4-Wall Switch Wireless remoter video.  I can see the button state change in Node Red using the debug option.
However the default behaviour without any programming is for the switch buttons to control the corresponding H16B relays, switch button 1-16 control H16B relays 1-16 directly.
After I configured Node Red in HA I can make Switch button 1 turn on H16B relay 2 but is also turns on relay 1, (by default).
Is there a way to turn off this default setting so the switch buttons don’t change the H16B relay states unless I configure it in Node Red?
Set up is
HA running Node Red
KC868-H16B V4.34  Work Mode: TCP Server for both Ethernet and Wifi
Switch Terminal Board V2.1 connect via Rs232
6 Gang Wall Self Reset Momentary Switch Toggle Button Dry Contact.  Connect via KCom and K1-K6
Any help would be appreciated.
Switch terminal board H16B relay default controll - by T920919 - 10-19-2022, 09:50 PM
