12-24-2022, 07:51 PM
[20:29:07][C][captive_portal:088]: Captive Portal:
[20:29:07][C][mdns:103]: mDNS:
[20:29:07][C][mdns:104]: Hostname: a128
[20:29:07][C][ota:093]: Over-The-Air Updates:
[20:29:07][C][ota:094]: Address: a128.local:3232
[20:29:07][C][ota:097]: Using Password.
[20:29:08][C][api:138]: API Server:
[20:29:08][C][api:139]: Address: a128.local:6053
[20:29:08][C][api:141]: Using noise encryption: YES
[20:29:13][D][esp32.preferences:113]: Saving 15 preferences to flash...
[20:29:13][D][esp32.preferences:142]: Saving 15 preferences to flash: 0 cached, 0 written, 15 failed
[20:29:13][E][esp32.preferences:145]: Error saving 15 preferences to flash. Last error=ESP_ERR_NVS_NOT_ENOUGH_SPACE for key=233825507
[20:29:27][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:29:28][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:29:33][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:29:33][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:29:33][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:29:38][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:29:38][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:29:39][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:29:44][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:29:44][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:29:44][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:29:49][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:29:49][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:29:49][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:29:54][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:29:55][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:29:55][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:30:00][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:30:00][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:30:00][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:30:05][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:30:05][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:30:06][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:30:11][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:30:11][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:30:11][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:30:13][D][esp32.preferences:113]: Saving 15 preferences to flash...
[20:30:13][D][esp32.preferences:142]: Saving 15 preferences to flash: 0 cached, 0 written, 15 failed
[20:30:13][E][esp32.preferences:145]: Error saving 15 preferences to flash. Last error=ESP_ERR_NVS_NOT_ENOUGH_SPACE for key=233825507
[20:30:16][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:30:16][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:30:16][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:30:21][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:30:22][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:30:22][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
[20:30:27][D][api.connection:159]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E) requested disconnected
[20:30:27][D][api:102]: Accepted ::FFFF:C0A8:14E
[20:30:27][D][api.connection:917]: Home Assistant 2022.5.5 (::FFFF:C0A8:14E): Connected successfully
