Kincony A16 - PIR motion sensor
you can try these code for KC868-A16:
platform: ESP32
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
address: 0x24
address: 0x25
address: 0x21
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
# Use pin number 0
# One of INPUT or OUTPUT
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_out_2
# Use pin number 0
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_in_1
# Use pin number 0
inverted: false
pcf8574: pcf8574_hub_in_2
# Use pin number 0
inverted: false
RE: Kincony A16 - PIR motion sensor - by admin - 01-03-2023, 01:30 AM
RE: Kincony A16 - PIR motion sensor - by admin - 01-03-2023, 05:19 AM
RE: Kincony A16 - PIR motion sensor - by admin - 01-03-2023, 09:16 AM
RE: Kincony A16 - PIR motion sensor - by admin - 01-03-2023, 12:33 PM
RE: Kincony A16 - PIR motion sensor - by admin - 01-04-2023, 01:21 AM
RE: Kincony A16 - PIR motion sensor - by admin - 01-04-2023, 11:59 PM
RE: Kincony A16 - PIR motion sensor - by admin - 01-07-2023, 06:14 AM
RE: Kincony A16 - PIR motion sensor - by admin - 01-07-2023, 08:00 AM
RE: Kincony A16 - PIR motion sensor - by admin - 01-08-2023, 02:06 AM
