01-05-2023, 04:18 PM
hello,
I use this config which works with the buttons too and are in the right order
platform: ESP32
sda: 16
scl: 15
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.1.199
# gateway: 192.168.1.1
# subnet: 255.255.255.0
address: 0x21
address: 0x25
address: 0x22
address: 0x24
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
#-----------INPUTS------------
on_press:
then:
- switch.toggle: output16
pcf8574: pcf8574_hub_in_1
on_press:
then:
- switch.toggle: output15
on_press:
then:
- switch.toggle: output14
on_press:
then:
- switch.toggle: output13
on_press:
then:
- switch.toggle: output12
number: 4
on_press:
then:
- switch.toggle: output11
number: 5
on_press:
then:
- switch.toggle: output10
number: 6
on_press:
then:
- switch.toggle: output9
number: 7
on_press:
then:
- switch.toggle: output8
pcf8574: pcf8574_hub_in_2
on_press:
then:
- switch.toggle: output7
on_press:
then:
- switch.toggle: output6
on_press:
then:
- switch.toggle: output5
on_press:
then:
- switch.toggle: output4
number: 4
on_press:
then:
- switch.toggle: output3
number: 5
on_press:
then:
- switch.toggle: output2
number: 6
on_press:
then:
number: 7
platform: ESP32
sda: 16
scl: 15
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
# manual_ip:
address: 0x21
address: 0x25
address: 0x22
address: 0x24
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
on_press:
then:
on_press:
then:
on_press:
then:
on_press:
then:
on_press:
then:
number: 4
on_press:
then:
number: 5
on_press:
then:
number: 6
on_press:
then:
number: 7
on_press:
then:
on_press:
then:
on_press:
then:
on_press:
then:
on_press:
then:
number: 4
on_press:
then:
number: 5
on_press:
then:
number: 6
on_press:
then:
number: 7
