01-17-2023, 12:55 AM
I hope simple question ;-)
i have temp sensor a dalles connected to the IO4 from esp32 on the KC868-server..
its a python question the relay for the serial print of the temperature i want it delayed 5000ms
but the control also delays 5000ms.. (that i realy dont want ;-))
for now i was only using RF but in time i maybe want a IR remote so it would be nice if RF and IR have NO delays...
Thx in advance!
here's my code test code:
#include <RCSwitch.h>
#include "PinDefinitionsAndMore.h"
#include <IRremote.h>
#include <OneWire.h>
#include <DallasTemperature.h>
long int keycode=0;
long int temp_keycode=0;
const int oneWireBus = 19;
OneWire oneWire(oneWireBus);
DallasTemperature sensors(&oneWire);
void setup()
Serial.begin(9600);
Serial1.begin(38400);
mySwitch.enableReceive(digitalPinToInterrupt(13));
sensors.begin();
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK, USE_DEFAULT_FEEDBACK_LED_PIN);
if (mySwitch.available()) {
Serial.print("Received ");
delay(0);
Serial.print(" / ");
Serial.print("bit ");
Serial.print("Protocol: ");
keycode=mySwitch.getReceivedValue();
if (keycode==5723139) {Serial1.print("RELAY-KEY-255,1,1");delay(100);} //toggle relay1
if (keycode==5723148) {Serial1.print("RELAY-KEY-255,2,1");delay(500);} //toggle relay2
if (keycode==5723184) {Serial1.print("RELAY-KEY-255,3,1");delay(500);} //toggle relay3
if (keycode==5723340) {Serial1.print("RELAY-KEY-255,4,1");delay(500);} //toggle relay4
if (keycode==5723343) {Serial1.print("RELAY-KEY-255,5,1");delay(500);} //toggle relay5
if (keycode==5723196) {Serial1.print("RELAY-KEY-255,6,1");delay(500);} //toggle relay6
if (keycode==5723199) {Serial1.print("RELAY-KEY-255,7,1");delay(500);} //toggle relay7
if (keycode==5723376) {Serial1.print("RELAY-KEY-255,8,1");delay(500);} //toggle relay8
if (keycode==5723331) {Serial1.print("RELAY-KEY-255,9,1");delay(500);} //toggle relay9
if (keycode==5723151) {Serial1.print("RELAY-KEY-255,10,1");delay(500);} //toggle relay10
if (keycode==5723388) {Serial1.print("RELAY-KEY-255,11,1");delay(500);} //toggle relay11
if (keycode==5723379) {Serial1.print("RELAY-KEY-255,12,1");delay(500);} //toggle relay12
if (keycode==5723391) {Serial1.print("RELAY-KEY-255,13,1");delay(500);} //toggle relay13
if (keycode==5723328) {Serial1.print("RELAY-KEY-255,14,1");delay(500);} //toggle relay14
if (keycode==5723187) {Serial1.print("RELAY-KEY-255,15,1");delay(500);} //toggle relay15
if (keycode==5723136) {Serial1.print("RELAY-KEY-255,16,1");delay(500);} //toggle relay16
mySwitch.resetAvailable();
if (IrReceiver.decode()) {
// Print a short summary of received data
IrReceiver.printIRResultShort(&Serial);
if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
// We have an unknown protocol here, print more info
IrReceiver.printIRResultRawFormatted(&Serial, true);
Serial.println();
delay(0);
IrReceiver.resume(); // Enable receiving of the next value
if (IrReceiver.decodedIRData.command == 0x15) Serial1.print("RELAY-SET-255,1,1"); //turn ON relay1
if (IrReceiver.decodedIRData.command == 0x16) Serial1.print("RELAY-SET-255,1,0"); //turn OFF relay1
if (IrReceiver.decodedIRData.command == 0x17) Serial1.print("RELAY-SET-255,2,1"); //turn ON relay2
if (IrReceiver.decodedIRData.command == 0x19) Serial1.print("RELAY-SET-255,2,0"); //turn OFF relay2
if (IrReceiver.decodedIRData.command == 0x1A) Serial1.print("RELAY-SET-255,3,1"); //turn ON relay3
if (IrReceiver.decodedIRData.command == 0x1B) Serial1.print("RELAY-SET-255,3,0"); //turn OFF relay3
if (IrReceiver.decodedIRData.command == 0x1D) Serial1.print("RELAY-SET-255,4,1"); //turn ON relay4
if (IrReceiver.decodedIRData.command == 0x1E) Serial1.print("RELAY-SET-255,4,0"); //turn OFF relay4
if (IrReceiver.decodedIRData.command == 0x1F) Serial1.print("RELAY-SET-255,5,1"); //turn ON relay5
if (IrReceiver.decodedIRData.command == 0x41) Serial1.print("RELAY-SET-255,5,0"); //turn OFF relay5
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,6,1"); //turn OFF relay6
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,6,0"); //turn OFF relay6
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,7,1"); //turn OFF relay7
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,7,0"); //turn OFF relay7
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,8,1"); //turn OFF relay8
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,8,0"); //turn OFF relay8
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,9,1"); //turn OFF relay9
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,9,0"); //turn OFF relay9
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,10,1"); //turn OFF relay10
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,10,0"); //turn OFF relay10
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,11,1"); //turn OFF relay11
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,11,0"); //turn OFF relay11
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,12,1"); //turn OFF relay12
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,12,0"); //turn OFF relay12
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,13,1"); //turn OFF relay13
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,13,0"); //turn OFF relay13
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,14,1"); //turn OFF relay14
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,14,0"); //turn OFF relay14
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,15,1"); //turn OFF relay15
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,15,0"); //turn OFF relay15
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,16,1"); //turn OFF relay16
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,16,0"); //turn OFF relay16
sensors.requestTemperatures();
float temperatureC = sensors.getTempCByIndex(0);
Serial.print(temperatureC);
Serial.println("ºC");
delay(5000);
Thx in advance!
long int keycode=0;
void setup()
Serial.begin(9600);
sensors.begin();
delay(0);
Serial.println();
delay(0);
delay(5000);
