KC868-A16 ESPHome led output not working
I tried turning on and off without any problem, esphome is working.
But when i check the board, the output led does not light up when i turn it on.
Below are the yaml i used, is there anything missing or wrong that causes the led not to light up when i switch it on using esphome?
Btw i have not connect or use any DC12/24v input yet.
# Example configuration entry for output input channel 1-16
  - id: 'pcf8574_hub_out_1'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_out_2'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8
    address: 0x21
  - id: 'pcf8574_hub_in_2'  # for input channel 9-16
    address: 0x22
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
Ops, connecting 12v DC Input by looping from the power, the led light up
KC868-A16 ESPHome led output not working - by stanchiam - 01-17-2023, 10:53 AM
