02-03-2023, 05:14 PM
(06-01-2022, 07:25 AM)admin Wrote: esphome:
type: arduino
ota:
password: "b9c07c109b7ecc6c63dac976c0c23a12"
wifi:
ssid: KinCony
password: xxxxxxxx
ap:
ssid: "A6 Fallback Hotspot"
password: "GLdHSsZr1p96"
captive_portal:
sda: 4
scl: 15
address: 0x24
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
do you have the modbus code example for sensor in ESPHome with KC868-A6 ?
Thanks,
