KC868-A6 LoRaWAN pinout issue
I'm trying to use MCCI LoRaWAN LCCI library to connect to the Things Network, however the library requires IO1 pin of the SX1278 module to be connected to an GPIO of the ESP32.
I soldered a wire from SX1278 IO1 to ESP32 GPIO13 as that appears free and looks like a suitable pin.  However after doing that, the serial port would no longer appear on my PC, when i removed the jumper wire everything returned to normal.
Can you suggest any solutions?  Is GPIO13 ok for use?
Thanks in advance.
Alex
KC868-A6 LoRaWAN pinout issue - by Alpha - 02-16-2023, 01:35 PM
RE: KC868-A6 LoRaWAN pinout issue - by admin - 02-17-2023, 12:39 AM
RE: KC868-A6 LoRaWAN pinout issue - by Alpha - 02-17-2023, 03:38 AM
RE: KC868-A6 LoRaWAN pinout issue - by Alpha - 02-20-2023, 01:48 PM
RE: KC868-A6 LoRaWAN pinout issue - by admin - 02-21-2023, 01:33 AM
RE: KC868-A6 LoRaWAN pinout issue - by Mandlap - 04-05-2023, 03:50 PM
RE: KC868-A6 LoRaWAN pinout issue - by admin - 04-06-2023, 12:52 AM
RE: KC868-A6 LoRaWAN pinout issue - by sergalpe - 02-01-2024, 01:12 PM
