Need help starting my smart home project
hello.
relay controller can work for AC110V or AC220V all is no problem. Suggest you can add a smart DB behind of your main power distribution box. Make a DB that smart control load. also you need to add AC contactor (if you use AC110V, just chose AC110V AC contactor is ok), because relay controller control AC contactor ON/OFF, not connect to load directly. So your lamp and socket is connect to your AC contactor.
we have a diagram for smart DB diy, I think will help you.
here is link: https://www.kincony.com/download/Smart-P...el-DIY.pdf
kincony relay box connect to AC contactor's line current is low, you can use diameter 1.5mm is ok. AC contactor output line with circuit break(MCB) that need thick,it's up to your load current or breaker's MAX current.
sensors you can connect to KC868-COLB logical controller.
you can chose kincony product online store: https://kincony.aliexpress.com/store/807891
use wired sensor is better. KC868-COLB MAX support 16 digital input sensor + 16 analog input sensor + 5 temperature sensor(-55 ℃ --- 125 ℃)
About the IP camera , I think you can chose "hikvision" products, also have NVR. you can use his system for monitor video and see video record.
if you want to use simple program for define light and dimmer, you can chose KC868-D8 dimmer controller work with KC868-COLB, that can set logical function by PC software, just use mouse click for automatic setting in graphic UI.
RE: Need help starting my smart home project - by admin - 02-10-2021, 02:20 AM
