RS485 not receiving anything
Question
I have the A16 wired up to a RS485 expansion board (16 inputs, 16 outputs) that is controlled by modbus RTU.
I have the ESP32 programmed with ESPHome. I can send commands to the expansion board, and I have control over the outputs (I see the onboard output-LEDs toggling), and I can see from the onboard communication LED on the expansion board that the expansion board sends a modbus response, but the ESP32 on the A16 does not receive anything on pin 16 (485RX).
I have verbose logs activated on the UART defined in ESPHome. I can see the raw bytes leaving on pin 13 (485TX), but no bytes are arriving on pin 16.
Obviously, I also cannot read the inputs of the expansion board (as that would require receiving the modbus response).
Are you sure that the RX pin number is correct? Could it be that I have a broken pcb trace?
Best regards,
Victor
P.S. Below is the relevant part of the esphome configuration
  level: VERY_VERBOSE
uart:
  tx_pin: 13
  rx_pin: 16
  baud_rate: 9600 #115200
  stop_bits: 1
  debug:
    direction: BOTH
    dummy_receiver: false
    after:
      timeout: 1s
    sequence:
      - lambda: UARTDebug::log_hex(direction, bytes,' ');
modbus:
  send_wait_time: 250ms
  disable_crc: true
modbus_controller:
  - id: eletechsup
    ## the Modbus device addr
    address: 0x1
    modbus_id: modbus1
    setup_priority: -10
   - platform: modbus_controller
     modbus_controller_id: eletechsup
     name: "read channel 1 state"
     custom_command: [ 0x01, 0x03, 0x00, 0x01, 0x00, 0x01 ]
     value_type: U_WORD
    name: "Eletech toggle 1"
    icon: "mdi:toggle-switch"
    address: 0x1
    register_type: holding
    skip_updates: 0
    lambda: |-
      return true;
    write_lambda: |-
      ESP_LOGD("main","Modbus Switch incoming state = %f",x);
      // return false ; // use this to just change the value
      payload.push_back(0x1);  // device address
      payload.push_back(0x6);  // write register
      payload.push_back(0x0);  // high byte address of the register
      payload.push_back(0x1);  // low byte address of the register
      payload.push_back(0x3);  // command (3=toggle)
      payload.push_back(0x0);  // delay (0)
      return true;
RS485 not receiving anything - by victorclaessen - 03-28-2023, 03:53 PM
RE: RS485 not receiving anything - by admin - 03-29-2023, 12:20 AM
RE: RS485 not receiving anything - by admin - 03-31-2023, 04:55 AM
RE: RS485 not receiving anything - by admin - 03-31-2023, 01:21 PM
RE: RS485 not receiving anything - by admin - 03-31-2023, 02:11 PM
RE: RS485 not receiving anything - by admin - 04-11-2023, 01:24 PM
RE: RS485 not receiving anything - by admin - 04-12-2023, 06:19 AM
RE: RS485 not receiving anything - by admin - 04-19-2023, 12:54 AM
RE: RS485 not receiving anything - by admin - 04-20-2023, 06:34 AM
RE: RS485 not receiving anything - by admin - 05-01-2023, 11:45 AM
RE: RS485 not receiving anything - by Yocee - 01-14-2024, 03:35 PM
RE: RS485 not receiving anything - by aucirc - 10-06-2024, 03:36 PM
RE: RS485 not receiving anything - by admin - 10-07-2024, 01:10 AM
RE: RS485 not receiving anything - by halbamy - 10-21-2025, 09:13 AM
RE: RS485 not receiving anything - by admin - 10-21-2025, 10:59 AM
