Need help with dimming my lights
at first i want to point out that i already have some of your boards used in my automation but not for the dimming.
The goal is to be able to dim these lights:
- 1 LED ceiling lamp, which is actually LED panel inside and it can work with 230V, or 24V DC but this lamp needs 100W power supply. It is dimmable with PMW(12/24V DC).
  https://shop.ledco.sk/loxone-svietidla-2...-2700k-65/  - you can check it here
- 4 LED ceiling lamp which are basically the same as the previous one but smaller and hence it needs only 60W power supply.
- 20 LED spot light GU10, 24V DC and needs 5W power supply.
- also a few LED strips will be there but those are irrelevant for now
When i was checking your boards only KC868-AP looked like a match but i was not sure if it can handle what i described. KC868-D16 is no go because it is without ESP32 and i want to be able to ESPHOME to be able to configure momentary switches clicks as i want.
Also i saw that you mentioned that you are developing a new board as ESP32 dimmer.
Can you please help me with this? What could work with the lights which i described?
Thanks in advance
Need help with dimming my lights - by zashiv - 04-29-2023, 11:04 AM
RE: Need help with dimming my lights - by admin - 04-29-2023, 11:12 AM
RE: Need help with dimming my lights - by zashiv - 04-29-2023, 11:40 AM
RE: Need help with dimming my lights - by admin - 04-29-2023, 12:05 PM
RE: Need help with dimming my lights - by zashiv - 04-29-2023, 12:16 PM
RE: Need help with dimming my lights - by admin - 04-29-2023, 12:34 PM
RE: Need help with dimming my lights - by zashiv - 04-29-2023, 12:43 PM
RE: Need help with dimming my lights - by admin - 04-29-2023, 01:41 PM
RE: Need help with dimming my lights - by zashiv - 04-30-2023, 09:24 PM
RE: Need help with dimming my lights - by admin - 05-01-2023, 02:23 AM
RE: Need help with dimming my lights - by zashiv - 05-02-2023, 07:40 AM
RE: Need help with dimming my lights - by admin - 05-02-2023, 08:29 AM
